Hello!
I created 2 fixtures with the same name, and company. The second fixture did not overwrite the first one, and I have two instances on the same name in the fixture list.
The Fixture folder shows only 1 instance of the fixture, and removing that results in Freestyler still showing the other available in the add/remove fixture list.
i cannot locate the other fixture file.
Tx a ton!
Sidhu
Fixture management
- FreeStyler Version: 3.3.2
- FreeStyler Version: 3.6.4
Re: Fixture management
Delete them from this location as well:
C:\Users\harvey\AppData\Local\VirtualStore\Program Files (x86)\FreeStyler\Fixtures
