Hello i use frestyler software for my moviehead DTX xr7 who is not in your program but a friend make me this model with creator .
i atached this file in my post for you for update the fixtured .
Now is my question :why i can create more than 15 steps in scenes ?
Anothers program has no limit in this but i can't use becouse my cable don't work...maybe you fix that or if is not possibile why not ?
I put music at the wedding and i need more that 15 step on the one scene .
Ok with steps now say to you about 3.3.7 beta,i install on my laptop 3.3.7 i make the scene i save the scene and after i closed program and open again when i want to play the scene who i save it the movie head make that scenes but in other position he cannot remind position who i make it..
With the 3.3.2 program this is not happend 3.3.2 works great .
I have a Oksidizer USB2DMX driver with usb 512 cable.i use this driver C:\Documents and Settings\Cippy\Desktop\driver_20060704\LISEZ-MOI.htm
i have a xp professional sp3 installed on my laptop cpmpaq nx9420
Thanks a lot .
no more 15 steps ?and problem with 3.3.7 beta
- FreeStyler Version: 3.3.2
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: no more 15 steps ?and problem with 3.3.7 beta
open up the freestyler.ini with administrator rights. it is placed in the Freestyler folder. Change the number for Number of steps.ciprianionut wrote:Now is my question :why i can create more than 15 steps in scenes ?
I'm sorry, but I do not understand the issueOk with steps now say to you about 3.3.7 beta,i install on my laptop 3.3.7 i make the scene i save the scene and after i closed program and open again when i want to play the scene who i save it the movie head make that scenes but in other position he cannot remind position who i make it..
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
- LJ
- FreeStyler Version: 3.2.8
I think he means, that the MH had an other position pointing to when running the scene, after closing and opening FS. But not sure...LJ_krede.dk wrote:I'm sorry, but I do not understand the issueOk with steps now say to you about 3.3.7 beta,i install on my laptop 3.3.7 i make the scene i save the scene and after i closed program and open again when i want to play the scene who i save it the movie head make that scenes but in other position he cannot remind position who i make it..
yes this is the problem after closing and after i opening FS when i load the scene the MH had other position pointing...i have the same problem with the 3.3.2 but i resolve that ...maybe in 3.3.7 need to make the same..
So when i want to save in create sequence and i create the scene for the MH runs corectly need to check "add to cue" ..if i do not check the MH doesn't work corectly
