We recently purchased 3 LED STRIPS and an enttec usb/dmx interface and were recommended to download freestyler. Unfortunatley the fixtures have not already been created and in trying to do so have found no such luck in getting them to cooperate/function using freestyler and fixture creator.
Just wondering if anyone has had any experience with the PRO SHOP range of lighting fixtures and could give any tips or advice on how to enter the strip into freestyler and gain functionality.
I found the manual on the http://www.showtech.com.au website and have it attached as well as our attemp at patching it into fixture creator..
If someone could give us some tips or pointers as to what we may be doing wrong, or if someone has this fixture in there own library and would like to share - we would be extremely grateful!
thanks guys...
Pro Shop/ Showtech Australia LED Strip EA-8080
- FreeStyler Version: 3.4.6
- Spirit
- FreeStyler Version: 3.5.9
Re: Pro Shop/ Showtech Australia LED Strip EA-8080
First all you dont need to be a Rocket engineer to Understand how FC works.
You also dont need to Know a Specfic Range of Fixtures The PDF or manual says it all, it all goes about the Channel Function.its realy easy.
but there is a Strange thing because both the PDF files says something else About the Channels.
So i'm not sure what would be correct.
but i would assume you also Have had a Manual With the Device.
Yeah i noticed the difference between the two pdfs the manual that came with the fixture says that channel one is function select, 2 - red 3 - green and 4 blue.
The manual i have is the same as the pdf copy attached with channels as stated above. Maybe im missing something...
