community_section:community_downloads
Community Downloads Section
Sound 2 FreeStyler DMX
Sound 2 Freestyler DMX is a tool to synchronize the speed of DMX lights to FreeStyler by the use of a midi sync clock. A midi clock from e.g. Traktor or a midi sync clock supported DJ mixer. Click here to download and more info
LuaFs - Lua Scripting
LuaFs - LuaScripting for Freestyler Click here to Download LuaFs 0.2
Telnet Server [Beta 4]
PDA Control Interface
FS configuration tool
Auto-Strobe Timer - Mattotone
iPhone / iPad Remote
Use your iPhone and iPad to control FreeStyler Click here for iPhone/iPad Application https://www.youtube.com/watch?v=cKCuloP21tA for videos
Sound 2 Light
Easy Freestyler Interface
Theater Cue Stack - Mattotone
Images for Fixtures - mmax
Freestyler DMX for Beginners
Joystic, gamepad or arrows
Joystic for Freestyler Control Pan / Tilt movement, set position and get the device, adjust the speed Pan / Tilt movement, especially in the use of balls and weddings. Click here to joystick 1.0.0.2
Fixture Library
The complete fixture library for FreeStyler and be found in this forum thread.
Fixture Library
community_section/community_downloads.1542352921.txt.gz · Last modified: 2018/11/16 07:22 by Jan_K
