community_section:community_downloads
Community Downloads Section
Sound2FreeStylerDMX
Sound 2 Freestyler DMX is a tool to synchronize the speed of DMX lights to FreeStyler by the use of a midi sync clock. A midi clock from e.g. Traktor or a midi sync clock supported DJ mixer. More detailed info and download at http://sound2freestylerdmx.liveski.be/
LuaFs - Lua Scripting
LuaFs - LuaScripting for Freestyler Click here to Download LuaFs 0.2
Telnet Server [Beta 4]
PDA Control Interface
FS configuration tool
Auto-Strobe Timer - Mattotone
iPhone / iPod touch Remote
Use your iPhone and iPod touch to control FreeStyler Click here for iPhone/iPod touch Application YouTube.com/iFSControl for video tutorials
Sound 2 Light
Easy Freestyler Interface
Theater Cue Stack - Mattotone
Images for Fixtures - mmax
Freestyler DMX for Beginners
Joystic, gamepad or arrows
Joystic for Freestyler Control Pan / Tilt movement, set position and get the device, adjust the speed Pan / Tilt movement, especially in the use of balls and weddings. Click here to joystick 1.0.0.2
community_section/community_downloads.1466965964.txt.gz · Last modified: 2016/06/26 18:32 by Yves
