Freestyler not working well on a Windows 11 machine
- Commited FS Forum helper
- FreeStyler Version: 4.6
Hello, I recently had to switch out a computer that i was using for Freestyler, it was windows 10 and put it on a windows 11 machine. I made a full backup of my setup and installed Freestyler 3.6.1 (I have tried 4.1.1) but I would have to re-due so many sequences, that I have not done yet, so still using the older version. I restore the backup file on the windows 11 machine, but then freestyler runs buggy, it seems like I click my mouse on something and something else gets selected, like the windows are not registering correctly. and sometimes it just freezes up. has anyone else had problems using a windows 11 machine?
- FreeStyler Version: 4.01
Re: Freestyler not working well on a Windows 11 machine
not sure but possible reasons he started the 4,,, series was to be compatible.
- djSupport
Windows 11 itself is still buggy! I had a loading mouse pointer for a good few months that was a known windows 11 bug that's just been fixed!
Thanks for the feed back, I think I will see if I can put windows 10 on it, or at least check for updates
- djSupport
No problem
