hello,
I have upgraded my FS, and I can't see anymore the Dist. (distribution) option, is it normal, is this option located somewhere else ?
many thanks for you support
fred
Dirstribution option for shapes in FS 4.1
- FreeStyler Version: 4.1
- djSupport
Re: Dirstribution option for shapes in FS 4.1
If no one comes back at you Fred, please pop this as a bug in the bug tracker to get feedback from the developer incase it's a bug
- FreeStyler Version: 4.01
I believe that the "delay" button on the right side of the window is what you are looking for.
Many thanks for your time guys.
The distribution button was able to desynchronize te rotation. I mean each beam will start with a delay.
Back to your point, the delay on the right hand side do not help. I can’t try again because I have downgrade my FS to the 3.6.51 version
- djSupport
So your saying that's missing from the latest version?
yes correct ! you can see on this picture next to offset
- djSupport
I'll look into that or you can pop it in as a bug and see what the developer says...
I just reinstalled 3.651 and compared the options to 4.1.1. All the same options are available just some are on the right side now. Distribute was renamed to Delay (exact effect in both versions)
- djSupport
Cheers for that info partyman
Many thanks party man I will try then
