Hi!
Starting to get it work.
Have I understand it right if I think it's not possible to invert the pan/tilt by Cue in a sequence?
/Rob
Invert by Cue? Topic is solved
- FreeStyler Version: 4.1.1Go
- FreeStyler Version: 4.01
Re: Invert by Cue?
You have to invert either in the actual fixture menu or in Freestyler by right clicking on the fixture on the freestyler desktop and selecting the option you want. It would not be inverting within a sequence, you are just programming a position.
Re: Invert by Cue?
Thanks.
So if I invert the channels when I make a cue it just save the value and not The invert command.?
Re: Invert by Cue?
bingo
Re: Invert by Cue?
Ok.
Then it would be some development potential to save the output value instead of the regular one.
Re: Invert by Cue?
Huh?
- djSupport
Re: Invert by Cue?
Your basically wanting to invert the fixture for that particular sequence, i.e. you have one sequence normal and one for inverted?
