Hey!
I'm new to Freestyler and DMX.
I have started to understand but have a problem.
I have searched the forum and seen others with similar problems but have not found a solution for me.
The problem is that when i save the sequence and load it again the strobe is changed.
I tried an simple example
Step 1: red light and strobe set to 0
Step 2: set strobe to 1
Step 3: set strobe to 127
Step 4: set strobe to 255
Step 5: set strobe to 0
It works fine at testing
I save the sequence and try and it work fine.
I Load the same sequence and now it changed.
Step 1: red light and strobe is 255
Step 2: strobe is 1
Step 3: strobe is 1
Step 4: strobe is 127
Step 5: strobe is 255
Now i'M SAD
What am I doing wrong?
Strobe change on save Topic is solved
- FreeStyler Version: 4.1.1Go
- FreeStyler Version: 4.01
Re: Strobe change on save
I believe the fixture file is not correct for that fixture. You may have to build a new one
