Hello,
I have a problem with Freestyler, or with Enttec Open DMX driver.
All lights and channels are working properly except Pan/Tilt. When I'm trying to use Pan/Tilt, the beam starting rotates a little and then stops, When I'm trying to use Round or Circle, beam works with cutting.
I've checked outputs, cables, tried to install Freestyler on computer with windows 7 / 64 bit, and Windows 10 / 64 bit, I installed new and old versions of Freestyler also, but the problem is same.
Anyone has any idea?
Problem with Pan/Tilt
- FreeStyler Version: 4.01
Re: Problem with Pan/Tilt
please provide more info, what fixtures, what mode, addresses...?
I've tried different beams (eg. sharpy), washes. I've tried to open a dimmer channels and move Pan Tilt faders but beams and washes are cutting or dont move.
Maybe there are a problem in Enttec Open DMX driver? because windows installed the FTDI driver automatically, maybe there was a problem?
