profile fixture for mini led spider beam light
- FreeStyler Version: 3.4.6
Hi. can anyone help me with a profile fixture for mini led spider beam light. 10/14 channel Thanks.
- FreeStyler Version: 4.1.6
Re: profile fixture for mini led spider beam light
Please supply either a link to the user manual or upload a PDF of the user manual
- FreeStyler Version: 4.01
Here is 14 Ch fixture, just double click file to install
Thanks Partyman. The fixture only run shows. I can't pan and tilt the motors. The led can't be switched on separately. I want to greate shows. Can anyone help please
dj charl - I can not tell from the user manual PDF you supplied but, based on your last comments, the instrument may be configurable to run without DMX. Please check. For the instrument to be controlled by Freestyler it must be configured to run in DMX mode - 14 channel DMX mode for the fixture supplied by Partyman.
Good evening, would anyone have the mini spider fixture for 3d?
That will probably be a very difficult fixture to make work in 3d
really, in addition to creating the channels in the ScanLib, there is no compatible device that has two Tilt's. Sorry for the writing, I'm using google translator.
