ColorPallet27ch Template
- Just started using FS
- FreeStyler Version: 2.96j
This is the best I could do. If you can improve it or make a better one, you'd help everyone that has this fixure out.
- DJ
Re: ColorPallet27ch Template
I made a few modifications and here's the resulting fixture file. I had trouble reading the macro text so I replaced those. Also, just like with the user guide, I had trouble remembering what each built-in program did (Auto/Sound Mode 1, Auto/Sound Mode 2, etc), so I renamed your macros to make them somewhat clearer. I hope this helps.
Regards,
-Guitartrooper
Regards,
-Guitartrooper
