Laser program
Lithium
LJ
Laser program
Post by Lithium »
I am using Freestyler for 2 months and it works verry well!
Now do i know someone that has a laser.
It is from Aston or something like that
Now am i looking for a program that i can make pictures for the laser.
I found a program but you need a commodore for it and i know a program but you need to buy it and you need to put an card in your computer
Is there some software thsta free to use?
Hope someone can help me
Erik
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Laser program
Post by Mattotone »
As far as i know you will require an interface being a simple dmx interface to access on board patterns or ilda to create your own.
But this also depends on which format your laser if any supports.
Lithium
LJ
Re: Laser program
Post by Lithium »
Hi thanks for posting,
I realy don't know what format the laser is i only know it is an aston laser but when i take a look at google i can not find anything...
What i have is the velleman kit for freestyler
Re: Laser program
Post by Mattotone »
The only way to make your own designs is through ILDA and will require a usb to ilda interface and a laser the accepts it.
They usually cost a lot of money, generally into the thousands range.
Dmx will allow you to customize pattenrs in terms of size, rotation blackout etc.
And again your laser must able to accommodate this.
mystery123
Re: Laser program
Post by mystery123 »
Not really thousands:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0225345277
Althrough you can't control it with DMX, only USB output from computer.
Michal
