Freestyler not communicating with Magic 3d Easy View Topic is solved
explosivejarvis
Post by explosivejarvis »
Hi All!! I opened easy view from freestyler like normal and added the same fixture to both sofwares but whenever i do something to the fixture (i.e. turn it on, move positions, change colors) nothing happens in easy view. Whats wrong? This is really pissing me off because it says that easy view is being controlled by freestyler. HELP!!
-explosivejarvis
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
You could test it with a single channel par can to make sure communication is ok, and that easyview shows freestyler connected with green light in corner.
Otherwise if you have any playback windows (like submasters, cue list, etc) open or override buttons pressed then the live output comes from them and not the bits you move.
Seems like a p.i.t.a. to start with, but once you get your head round it it's actually really useful being able to create basic colour schemes or scenes on the fly.
Rosspunk
Re: Freestyler not communicating with Magic 3d Easy View
Post by Rosspunk »
Hey Spud, I can't seem to get Freestyler communicating either. Maybe it's because i am using XP still. I have tried the windows 7 fix (in an earlier post). Great bit of software by the way!
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
If I remember correctly xp should be one of the easiest ones to get running, vista was the most annoying. What problems are you facing, Rosspunk?
Rosspunk
Post by Rosspunk »
When I launch Easy View from Freestyler it shows that it is controlled by freestyler, but there is no DMX. I have the virtual dmx option selected in freestyler. Should i get a drop down option in the dmx universe in Easy View?
Nathanrs93
If you have no DMX then that's the MEVP protocol link between FS and 3D view. You need to make sure you have your interface on virtual interface in FS setup and you have copied the files correctly like it says in windows 7 fix. That's it :)
If you are still having trouble I can do a video call over skype and help you if you want?
Rosspunk
Post by Rosspunk »
I will try again tonight. When i have unzipped the MEVP file and replaced the existing file do i also need to unzip the other 4 'sample' files within the MEVP folder?
Nathanrs93
- In the Magic 3D Easy View beta folder, extract the contents of MEVP.zip to your FreeStyler folder, overwriting files when prompted.
-Copy EasyView.exe from the Magic 3D Easy View beta folder to your FreeStyler folder (overwrite the old one when prompted).
Rosspunk
Post by Rosspunk »
I have now tried this twice. Maybe we could talk. How about tomorrow?
Nathanrs93
Yeah, tomorrow is fine as I'm in all day
Rosspunk
Post by Rosspunk »
Tried everything, now getting the hump. :(
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Are you on XP?
You could try the windows 8 Fix that I am working on. I will try add it tonight. Using the Microsoft Loopback Network Adapter. (It is a Virtual Adapter)
buttza
Loopback Setup!
Post by buttza »
Hi I need someone to try this tutorial to see if it works for you. Thanks.
Loopback_setup.pdf
(462.39 KiB) Downloaded 391 times
Rosspunk
Post by Rosspunk »
Buttza, Yes I am still on XP.
buttza
Post by buttza »
Hey Rosspunk you could try the instructions I created below. It should work for XP.
viewtopic.php?f=56&t=6406
Polsound
Post by Polsound »
hey there guys
i seem to have an issue with my win7 and running easyview. all problems came up after upgrading from XP. yes, ive tried the win 7 fix, downloaded and installed everything as it should be but the FS doesnt seem to communicate with 3D. its says that it is controlled by FS and the DMX is on in ECO mode. still nothing.
also, im not sure if its win7 or videocard or setting problem but on the stage the screen doesnt load up the video normally only on the right upper corner of the screen and not on full screen mode. what the hell is this?
pls pls pls help!
this whole thing is going on my nerves.
any suggestions?
many many many thanks for the answers
Nathanrs93
Have you tired doing it the way Buttza in the post above??
danielvee
Post by danielvee »
I am having a similar problem , I'm on windows 7 , dmx is on virtual , load it from fs patch basic par cans , line up patches , dmx light is red in right corner , ??? ,really need some help on this one , totally doing my head in , I also have another laptop I tried to run this on , on the second laptop , MeV won't even launch from fs ,
Sent from my iPhone using Tapatalk
buttza
Post by buttza »
danielvee
Post by danielvee »
The universe options on mev start up screen are grey and can't b altered , dmx light in right corner is red ?????
danielvee
Post by danielvee »
I have followed all instructions
danielvee
Post by danielvee »
danielvee
Post by danielvee »
Heeeellllllppppppppp
danielvee
Post by danielvee »
Can somebody post the windows 7 fix
buttza
Post by buttza »
See image
